Date/Time: Wed, 27 Nov 2024 08:44:42 +0000
How to have 2 independent OCO strategies
View Count: 1185
[2014-08-18 18:37:03]
trial04225 - Posts: 6
I current has one OCO strategy. It has 2 contract in it.
And I want to add another 1 contract OCO strategy, how do i add it so i can have 2 strategies at the same time.
[2014-08-19 09:31:41]
If we are understanding this correctly, then what you need to do is just change the quantity on the Trade Window to 1 and submit another order.
When you say OCO strategy are you referring to an order with Attached Orders?
Here is the documentation for the Trade Window:
https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindow
Date Time Of Last Edit: 2014-08-19 09:32:00
[2014-08-19 14:48:13]
Yes, 2 attached orders.
I can change the existing attached order, to 1 quanity, however after its changed, it says invalid number, since its set to have 2 units.
That's why i was asking if i can have 2 sets of attached orders.
[2014-08-20 04:00:14]
OK, we have a better understanding of what you want.
You have to save 2 different Trade Window configurations. Each one with different quantities and different defined Attached Orders.
Here is the documentation for that:
https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations
You can easily switch between the two using the drop-down list box at the top of the Trade Window.
[2014-08-20 20:21:35]
Thanks. That's how I want the trading dom to be. :)
