Date/Time: Sun, 24 Nov 2024 15:52:38 +0000
Scroll End indication
View Count: 156
[2024-05-16 16:32:48]
drmike_dxb - Posts: 8
Hi
Can you please help to remove SCROLL END indication in the bottom right corner entirely?
[2024-05-16 16:32:51]
There is not a way to remove it. The best you could do is to change the background options to be the same as the chart background, but the test will still be present. Refer to the following:
Graphics Settings: Scroll End Color
[2024-05-16 17:00:24]
ok undersood thanks.
Thats exactly what Ive done. I thought its possible to remove unnecessary letters/symbols to declutter charts
thanks anyway
