Date/Time: Sun, 24 Nov 2024 15:29:04 +0000
Simple Alert Condition Formula Programming Help
View Count: 207
[2024-05-16 16:27:56]
shah - Posts: 7
I am using the "Numbers Bars Calculated Values" study and I am using "High Ask Volume Percent" and "Low Bid Volume Percent" sub graphs.
I am trying to write an alert condition i.e. if any of the sub graph values in less than 0.5 raise an alert (or do something i.e. show value on top/bottom of bar).
Below is the condition am writing which doesn't seem to work.
=ID1.SG46 < .3
and
=ID1.SG45 < .3
But., e.g. I still see the value .37 on top/bottom of some bars.
Thank you,
[2024-05-16 16:28:36]
Refer to the following:
Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas
