Date/Time: Wed, 27 Nov 2024 08:46:39 +0000
CLR version
View Count: 1075
[2014-08-18 18:35:35] |
Dennis B. - Posts: 272 |
In your newest upgrade (1174) which one is the non-clr version ?
[2014-08-18 20:29:46] |
We are not understanding the question. You can download either the CLR or non-CLR version through the Help menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-18 21:02:53
[2014-08-18 20:37:53] |
Sawtooth - Posts: 4120 |
The one that says 'New Spreadsheets" is the non-CLR version.
[2014-08-18 21:03:32] |
Yes, this is correct. The Download commands on the Help menu that say ( New Spreadsheets) are the non-CLR version. On the Help menu we do not use the CLR terminology. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-18 21:04:11
