Date/Time: Sun, 24 Nov 2024 15:41:41 +0000
Relative Volume study
View Count: 251
[2024-05-16 13:56:57] |
User213504 - Posts: 69 |
The study is not displaying properly on my chart. I have a combination chart with a comparison chart of indexes, volume, NYSE Advance/Decline and Relative Volume. The Relative Volume is not displaying as per the attached pic. The study displayed correctly when I first applied it but the next day I got what you see. I am also displaying the Cummulative Volume Ratio on another chart and the same thing happened. The first time applied it was correct but today it displayed the day's relative volume. I went into the settings and clicked the Apply button and it corrected itself.
Date Time Of Last Edit: 2024-05-16 14:02:46
relative volume.png / V - Attached On 2024-05-16 13:56:41 UTC - Size: 94.75 KB - 64 views |
[2024-05-16 15:44:07] |
Reset the scale for the region that has the Relative Volume study in it. Refer to the following: Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-16 15:53:55] |
There is a problem with the scale settings. The A/D area and the RVol scales are conflicting. The A/D area has a range of 3000 and the RVol area resets to 0. I'll delete this chart and rebuild it and see what happens.
[2024-05-17 13:36:37] |
Rebuilt chart works correctly. Thank you. Ron |
