Date/Time: Sun, 24 Nov 2024 15:37:09 +0000
question about packages
View Count: 177
[2024-05-16 13:45:52]
User890667 - Posts: 1
hi! i find your packages and options a bit confusing. i want to trade indices and stocks on us market and eurex with DOM. besides packages 11 what do i need to buy to get this?
[2024-05-16 15:40:51]
Besides the package, it depends on where you are getting your data from. If you will be getting your data from your trading service, then there is nothing else you need.
If you want to get the data from us, then you would need to setup the data. To enable the data for our "U.S. Equities Consolidated Tape" and for "EUREX", follow through the instructions at the following link:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
