Date/Time: Sun, 24 Nov 2024 16:06:35 +0000
Missing data 211104 - 230311 in mthly vbp chart
View Count: 248
[2024-05-16 07:44:46]
Benz - Posts: 46
Hey guys,
My mthly vbp is missing the data from days including 211104 - 230311
I've provided screen shots with the crosshairs showing the break.
I've provided screenshots for chart settingsexcept im limited to one of those.
I've tried many settings and have deletd all data and redownloaded etc.
Advise pls?
Thank you :D
imageScreenshot 2024-05-16 083008.png / V - Attached On 2024-05-16 07:39:09 UTC - Size: 47.19 KB - 50 views
imageScreenshot 2024-05-16 083051.png / V - Attached On 2024-05-16 07:39:17 UTC - Size: 47 KB - 49 views
imageScreenshot 2024-05-16 settings.png / V - Attached On 2024-05-16 07:44:32 UTC - Size: 120.3 KB - 45 views
[2024-05-16 13:55:07]
Sierra_Chart Engineering - Posts: 17156
Follow these instructions:
[2024-05-17 08:06:13]
Benz - Posts: 46
I've painstakingly done what you suggested and gone carefully through every step 3 times. It hasnt solved the problem.
I've now realised this is effecting other monthly charts. NQ screenshot attached.
As you can see from following your instructions it is now easy to see the missing contracts.
There are more/different missing contracts from NQ than ES? I dont know if that helps understand the situation.
What next please?
Thx
imageScreenshot 2024-05-17 085343.png / V - Attached On 2024-05-17 08:01:31 UTC - Size: 50.83 KB - 40 views
imageScreenshot 2024-05-17 085357.png / V - Attached On 2024-05-17 08:01:37 UTC - Size: 58.84 KB - 54 views
[2024-05-17 10:14:38]
Benz - Posts: 46
Ok so i am able to get all the contracts to show in chart when using Historical Chart.
Obviously this doesnt give me the volume intraday profile data i am looking for on my studies.
It is only when switching to Intraday Chart i am losing contracts (the Intraday Chart setting was provided to you on original screenshot).
Maybe this will assist getting to the answer?
Please advise.
Thank you.
[2024-05-17 14:44:05]
Maybe the historical Intraday data downloads are failing. Therefore, set this to 10 seconds or higher:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
And then follow through the instructions here again:
And be sure to download data for all of the contract months. In the list of contracts, select all of the symbols in the list. Just do not re-download data for the current contract.
Date Time Of Last Edit: 2024-05-17 14:44:18
