Date/Time: Sun, 24 Nov 2024 16:44:03 +0000
Spreadsheet J26 is not Updating Order Quantity.
View Count: 179
[2024-05-16 03:22:41] |
User384855 - Posts: 5 |
Spreadsheet J26 is not Updating Order Quantity, I have tried So many times but its not working, is there something that's missing ? Thanks |
Attachment Deleted. |
[2024-05-16 15:01:02] |
Cell J26 does not update with the actual quantity that is selected. This cell allows you to set a quantity that you want to use for the Spreadsheet System for Trading. So any value entered in this cell will be used for the quantity for orders that are placed from the Spreadsheet System for Trading. If the cell is empty, then the quantity used will be the quantity set on the Trade Window. Otherwise, there is no connection between the value set in cell J26 and the quantity set in the Trade Window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
