Date/Time: Sun, 24 Nov 2024 16:34:12 +0000
Numbers Bars Study Doesn't show correct numbers
View Count: 160
[2024-05-16 01:24:17] |
User130773 - Posts: 2 |
https://www.sierrachart.com/image.php?Image=1715822521542.png The numbers bar study is only showing very small numbers. The Numbers Bar Calculated Values for instance, only show mostly zeros and ones. |
[2024-05-16 01:33:37] |
Sierra_Chart Engineering - Posts: 17156 |
Change to June 2024 contract: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-16 01:39:35] |
Excellent support!
