Date/Time: Sun, 24 Nov 2024 16:52:08 +0000
Fibonacci Retracement using High/Low for each volume-based bar?
View Count: 171
[2024-05-15 21:20:16] |
User656492 - Posts: 143 |
It appears that the current auto-retracement/projeciton study is only time based. How can I implement this using high / low of each individual volume bar on my chart? Thanks! |
[2024-05-16 14:51:48] |
There is not way to do this with the way the study is setup. You could modify the source code and have it work as you want. The study is available in the Studies6.cpp file in the ACS_Source folder under your main Sierra Chart installation folder. Refer to the following: How to Build an Advanced Custom Study from Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
