Date/Time: Sun, 24 Nov 2024 16:40:58 +0000
Chart Region 2 study disappears from view
View Count: 172
[2024-05-15 18:32:50] |
User672422 - Posts: 8 |
Why do Studies in Chart Region 2 disappear from view? The Study either disappears to the top or bottom of Chart Region 2 Sierra Chart Version 2634 64-bit Revision 50081 Chart Region 1: NQM24 Chart Region 2: MACD and Horizontal Lines studies |
[2024-05-15 21:02:33] |
It depends on the values that you are showing for the studies. Refer to the following: Chart Scale and Scale Adjusting: Displaying Multiple Graphs in Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
