Date/Time: Sun, 24 Nov 2024 16:47:30 +0000
Persistant veriables using time instead of bars
View Count: 136
[2024-05-15 04:53:12] |
aswade3451 - Posts: 19 |
Hi SC team, I know that I can use the example provided in the documentation "Persistent and Incrementing variables" to count the amount of bars since an event, but is there an example or a way I can count the amount of time a event has occurred instead? Or maybe a way to reference the current time vs the time an event occurred? Thanks! |
[2024-05-15 11:40:38] |
Sawtooth - Posts: 4119 |
You can modify this example to measure time since an event: Spreadsheet Example Formulas and Usage: Cancel Unfilled Working Order n Minutes After Entry The event start time is in Y3/Z3. The measure of time since an event is in the J27 formula. |
