Date/Time: Sun, 24 Nov 2024 16:44:23 +0000
Will using a SIM account as a master account help with copying?
View Count: 182
[2024-05-15 03:57:33] |
trad - Posts: 43 |
Are copied orders sent after confirmation is received from the original order sent to the master account? If that is indeed the case, will using a SIM account as the master improve the copying speed? I am considering this because the SIM might be filled quickly, possibly even locally. |
[2024-05-15 15:07:12] |
If you are referring to the "Order Allocation to Trade Accounts", then copied orders are sent at the same time as the original order. There is no waiting for anything from a "Master" account. If you are using a third party tool, then you would need to ask the creators of that tool. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
