Date/Time: Sun, 24 Nov 2024 16:51:38 +0000
Order fills not showing after Topstep rebill
View Count: 259
[2024-05-15 02:22:04] |
User910963 - Posts: 80 |
I started a combine February 16. It ended April 19. When I go back to see my fills on the chart, I can only see 2 days worth of trading starting from 4-17 to 4-19. I was rebilled every 16th, and the prior data seems to not be showing on the chart. Is there a way to view the fills since I am logged into the trading service?
[2024-05-15 15:04:06] |
If the order fills are in your Trade Activity Log, but not showing on the chart, then refer to the following: Chart Trading and the Chart DOM: Chart Order Fills Do Not Display If the fills are not in your Trade Activity Log, then you would have to see if you can recover them from a backup of the logs. Refer to the following: Trade Activity Log: Restoring Backups of Trade Activity Logs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-15 15:05:01
[2024-05-15 19:15:11] |
Thank you.
