Date/Time: Sun, 24 Nov 2024 15:25:46 +0000
Merging Number Bars
View Count: 329
[2024-05-15 01:01:35] |
User688525 - Posts: 257 |
Hello Sierra Chart, Is there an option to merge Numbers Bars similar to how individual TPO periods are merged? If this isn't existing functionality (or already in the works), is this something that would be considered? Thank you |
[2024-05-15 14:54:11] |
This does not currently exist. There are a couple of options for what you are asking for: 1) Change the time frame of the chart. If you are using 1 minute bars, change to 2 minute bars to merge the data. 2) Create a custom study with Custom Chart Bars that have the bars the way you want. Refer to the following: ACSIL Interface - Custom Chart Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-17 07:46:35] |
Hi John, Thank you for the options. After customizing the Draw Volume Profile tool, this will likely meet my needs. |
