Date/Time: Sun, 24 Nov 2024 14:40:27 +0000
Liquidity data bank
View Count: 297
[2024-05-14 21:56:47] |
User913209 - Posts: 7 |
Bonjour savez vous où trouver les liquidity data bank sur le market profil ? Merci
[2024-05-14 21:57:32] |
From Google Translate: Hello, do you know where to find the liquidity data bank on the market profile? THANKS
We have no idea what you are referring to in terms of the "Liquidity Data Bank". Can you give us more information on exactly what you are looking for? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-20 17:27:45] |
cest un moyen de voir qui sont les intervenants sur le marché a quelle pourcentage etc etc
[2024-05-20 21:00:29] |
From Google Translate: it's a way to see who the players are on the market at what percentage etc etc
We think you are looking for the Market Depth information. You have the "Full CME Group with Market Depth" exchange active, so you should be getting the Market Depth data for any instrument traded with the CME Group. Refer to the following if you are having an issue viewing the Market Depth data: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns It is also possible you are referring to the Market By Order data. For this, refer to the following: Market By Order Data What has us confused is that in your first post you reference the "Market Profile" and you also mention percentages in your last post. For the Market Profile, refer to the following: Time Price Opportunity (TPO) Profile Charts If it is still something else you are looking for, then we need yet more information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
