Date/Time: Sun, 24 Nov 2024 16:09:24 +0000
I am having problem display number bar chart: BTC
View Count: 230
[2024-05-14 21:55:33] |
kkc8 - Posts: 2 |
I am trying to load BTCUSDT binance chart. I am having problem display number bar chart. I watched the number bar video tutorial already from your web site. I do not know what setting I need to use to get the readable display that I want. Please help. |
[2024-05-14 21:56:10] |
Refer to the following: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-16 18:51:31] |
kkc8 - Posts: 2 |
Asset: BTCUSD_PERP_BINANCE I have try to change the tick size to 1, however it keep change it back to "0.0100". "https://www.sierrachart.com/index.php?page=doc/CryptocurrencyDataServices.php#VolumeAtPriceStudiesWithCryptoCurrencySymbols" Nothing is working in term of number bar display for BTC. Please help. |
Attachment Deleted. |
[2024-05-16 20:32:36] |
VLiviu - Posts: 223 |
click "edit global symbol settings" and modify the symbol directly there
[2024-05-16 20:38:01] |
If you want to change the Tick Size, you need to first set the option for "Auto-Set from Data Feed" to "No". Then you can change the Tick Size and have it stick.
