Date/Time: Sun, 08 Sep 2024 00:24:48 +0000
Period OHLC-Variable Period - Feature Request - To add Reference Periods Back
View Count: 165
[2024-05-14 09:56:37] |
SierraUser - Posts: 3 |
Dear Sierra Chart Team, With regard to the Period OHLC - Variable Period Study, would it be possible to add a <Reference Periods Back> option to display beyond the most recent non-current period, similar to the <Reference Days Back> in the Daily OHLC study? Thank you. |
[2024-05-14 14:42:31] |
Sierra_Chart Engineering - Posts: 16292 |
Best thing is to modify the study to meet your requirements. Source code is available: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-24 16:37:44] |
User314524 - Posts: 14 |
Hi I would love to do this as well, but i wouldn't have a clue how to code anything. did you get this to work somehow? Thanks |
