Date/Time: Sun, 24 Nov 2024 17:01:50 +0000
Trial Version for saving chartbooks and getting constant data feed disconnect messages
View Count: 145
[2024-05-14 03:58:05]
cmack1011 - Posts: 51
Hi
I am currently using the trial version but every time I log off the system is not saving my chartbooks even though I save them to the chartbook log - please advise. Also, I am now getting a constant data feed disconnect - re-connect log window. Thx
CNM
[2024-05-14 15:51:18]
We see you are using a Mac. Make sure you have Sierra Chart installed in a proper writable folder.
Regarding working with Chartbooks, refer to:
Chartbooks (Workspaces)
For connectivity issues, refer to to:
Data/Trading Service Connection and Symbol Issues
