Date/Time: Sun, 24 Nov 2024 16:44:39 +0000
Checking if support scale in/scale out is enabled
View Count: 158
[2024-05-13 20:58:19]
User389369 - Posts: 6
Hi, is there any way to quickly check if scale in/scale out functionality is enabled without having to open the trading menu and then hovering over the "Orders" option.
I have the Support Scale In/Scale Out buttons attached to a hotkey and want to be able to quickly toggle it on/off without opening the menu. It'd be great if there was a way I could see whether these configurations are enabled without having to open any windows.
[2024-05-13 21:48:51]
The only built-in option for this would be to add the Control Bar buttons for "Support Scale In" and "Support Scale Out", this way you can view the status of the control bar button to see if it is on/off.
Otherwise, you could create a custom study that gives you some kind of notification on the screen for when it is on/off. Refer to the following:
ACSIL Interface Members - Variables and Arrays: sc.SupportTradingScaleIn
List of Third Party Sierra Chart Study and System Programmers
[2024-05-14 12:27:07]
Thank you! That's exactly what I was looking for
