Date/Time: Wed, 27 Nov 2024 08:41:09 +0000
Copying my custom study to another computer
View Count: 1577
[2014-08-18 14:13:40] |
User120827 - Posts: 77 |
Hi I made a custom indicator in Sierra on my computer and would like to copy it to another computer. Is it just the dll I need to copy to another computer ? thanks regards |
[2014-08-18 16:43:19] |
Yes. You will need to copy the DLL file only. This will be located in the Sierra Chart Data Files Folder which is set through Global Settings >> General Settings.
[2014-08-18 17:46:35] |
ok Thank you ! regards |
[2014-08-18 18:02:59] |
User021827 - Posts: 174 |
Hi After moving the dll to other computer, I got this message when trying to load it from studies. Error loading C:\SierraChart\Data\shane2withattachedorder.dll. Windows error code 126: The specified module could not be found. | 2014-08-18 14:00:40 On the original computer, there were other files, exports library file, object file library, incremental linker. I created it in Microsoft Visual Express 10 Should I copy those as well ? regards Date Time Of Last Edit: 2014-08-18 18:11:09
[2014-08-18 18:15:00] |
You probably will need to install the Visual C++ 2010 redistributable package on the other computer.
[2014-08-18 18:29:17] |
hi Ok thanks If I had used Sierra compiler, then I wouldnt have to do that ? thanks Shane |
[2014-08-18 20:30:13] |
No you would not.
