Date/Time: Fri, 19 Apr 2024 23:45:41 +0000
Continual checking for Level II?
View Count: 1537
[2013-05-07 13:23:00] |
TI Anon - Posts: 36 |
SC is continually checking for Level II authorization in IqFeed. Once it is checked on startup, is there a reason to continue running the routine? (FYI: I do not subscribe to Level II data) V791, IQFeed ver 5.0.0.11 |
[2013-05-07 16:20:59] |
We have heard this will be resolved in the IQ Feed client software version 5.1. It is the IQ Feed software continuously sending that message. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
