Date/Time: Sun, 24 Nov 2024 16:35:49 +0000
Default watchlist/auto-attach watchlist to new chart
View Count: 179
[2024-05-13 08:45:36]
User840187 - Posts: 5
Good morning.
Is there a way to auto attach a specific symbol watchlist to every new chart?
That would really be handy.
So far, I've been attaching it manually through the watchlist dropdown in the control bar.
Thank you in advance for your help.
Date Time Of Last Edit: 2024-05-13 08:47:22
[2024-05-13 16:50:02]
Not as such. But what you would want to do is use a chart as a "Template" that has the Control Bar on it with the Watchlist item. Then duplicate that "Template" and change the symbol to get the chart you want with the watchlist attached.
Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
