Date/Time: Sun, 24 Nov 2024 16:46:27 +0000
During the trial period, USOIL charts cannot be opened and displayed.
View Count: 184
[2024-05-13 08:39:36]
User877604 - Posts: 2
https://www.sierrachart.com/image.php?Image=1715589534698.png
https://www.sierrachart.com/image.php?Image=1715589627519.png
The above is a gold chart, which can be displayed normally.
https://www.sierrachart.com/image.php?Image=1715589793862.png
https://www.sierrachart.com/image.php?Image=1715589828311.png
This is from USOIL
Date Time Of Last Edit: 2024-05-13 08:44:39
imagephoto_2024-05-13_16-26-56.jpg / V - Attached On 2024-05-13 08:28:23 UTC - Size: 130.46 KB - 61 views
[2024-05-13 16:42:53]
You should not be having an issue for either USOIL or for CL. If you are still having an issue, then please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
