Date/Time: Sun, 24 Nov 2024 16:49:42 +0000
Delta Tick Volume
View Count: 317
[2024-05-13 06:22:37]
User904434 - Posts: 54
Do you have such indicator which is showing delta in ticks, for exemple delta volume is changing but delta tick volume is not changing at same time. Thanks.
[2024-05-13 13:56:52]
Sierra_Chart Engineering - Posts: 17156
We do not know what is meant by delta in ticks. We do not understand this. We need a precise and clear explanation of what you want.
And typically the word Delta has to do with the difference between Ask volume and Bid volume. But use those words instead, and also ask volume and bid volume of what specifically. For example, the ask volume and bid volume, of a particular chart bar.
