Date/Time: Sun, 24 Nov 2024 16:37:07 +0000
How to reverse the order of the activity log to show new executions (and total P/L) on top.
View Count: 258
[2024-05-12 20:59:39]
User740504 - Posts: 110
The Activity log enters executions from top to bottom. I have to continuously scroll to the bottom of the window as it overtakes the window size. Is there a way to sort them from new to old so new executions are on top and I'm always aware of the latest execution and current P/L for the day without having to scroll down?
Thanks.
Date Time Of Last Edit: 2024-05-13 00:06:43
[2024-05-13 15:52:58]
On the Trade Activity Log select "Edit >> Descending Display Order". Refer to the following:
Trade Activity Log: Edit >> Descending Display Order
[2024-05-13 15:59:05]
Sorry, I meant for the Trades tab. Descending Display Order doesn't work there. I should have mentioned that earlier. I think I'm out of options here. No big deal.
Date Time Of Last Edit: 2024-05-13 15:59:11
[2024-05-13 19:34:23]
The option for "Descending Display Order" works on the Trades page. But the first ordering is going to be by symbol, and there is not a way to change that. But within a symbol group the Descending Display Order option will change how the orders are listed.
[2024-05-13 21:21:55]
seandunaway - Posts: 268
i think it only works when not using flat to flat display
[2024-05-14 02:29:37]
Thank you both. Yes, untoggling Flat to Flat Display allowed it to work.
