Date/Time: Sun, 24 Nov 2024 13:04:40 +0000
data feed
View Count: 309
[2024-05-12 12:17:13] |
User785809 - Posts: 18 |
Hi I have been paying for full CME data feed for 2 computers, However another trader I know advised me I only need denail data, I only use pound futures data nothing else, if this is correct can you change the data feed to this for me as am not 100% sure how to do this. I pay for two data feeds thankyou |
[2024-05-12 15:59:13] |
Sierra_Chart Engineering - Posts: 17154 |
You can definitely save money. Do you need market data, on two computers at the same time or just one? We will get this modified for you, on Monday but it will not go into effect until next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-12 16:54:06] |
Hi Great I need market data for 2 computers running at the same time .. Thank you for sorting this out for me... Can you let me know the costs now, Think I remember being told it was $12 per data feed |
[2024-05-12 21:45:46] |
It is 12.50 per month for the exchange fee and 2 systems would make it 25. You can see this here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed This is the exchange fee that you will need to activate at the beginning of June: CME with Market Depth for non-professional Trading accounts We disabled the full CME Group from renewing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-12 21:46:04
[2024-05-13 07:32:31] |
Hi thanks for doing this. However my footprint has stopped working since you made these changes on the CME data, please can you advise how to rectify this
[2024-05-13 10:35:51] |
Can you also change the feed to just one computer I know longer need two computers running at the same time with data feed thankyou
[2024-05-27 16:32:32] |
You still have real-time data for the entire CME Group with market depth data. Nothing has changed with that. And you do have access to Numbers Bars. Are you still having a problem with Numbers Bars? The number of systems is set to 1 for exchange fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
