Date/Time: Sun, 24 Nov 2024 16:28:11 +0000
Replay Not Working for All Charts
View Count: 332
[2024-05-12 01:24:29]
mastadom - Posts: 5
Replay function does not work for all charts in chartbook. It only replays the DOM window.
I tried to replay the yesterday session (which was Friday, May 10, 2024)
I followed the instructions on https://www.sierrachart.com/index.php?page=doc/ReplayChart.html, but still can't make it work.
Charts included in the chartbook:
- 4 candlestick charts (1m, 5m, 30m, 1y)
- 2 footprint charts (1 footprint chart with Trade DOM)
- 1 DOM
All charts in this chartbook have the same following settings:
- Time Zone: Los Angeles
- Continuous contracts: Continuous Futures Contract - Volume Based Rollover, Back Adjusted
- Days to Load for Intraday Chart Data Type: 30
Replay options:
- All Charts in Chartbook
- Replay Mode: Calculate At Every Tick/Trade
When I click the play button, I select "Clear All Trade Data for Symbol and Account", then 60 for "Enter Processing Step in Seconds".
The one DOM window replays properly, but none of the other charts replay. I am starting replay from an intraday footprint chart with Chart DOM on (not the DOM chart only window).
[2024-05-13 15:27:03]
From the documentation:
When multiple charts are being replayed when using Calculate at Every Tick/Trade and you are prompted for the Processing Step In Seconds even though there is a calculation at every tick, there still are multiple ticks processed per chart for the specified time increment in seconds before going onto the next chart to be calculated.
So with a Processing Step In Seconds of 60 you may not see any particular chart update for as much as 7 minutes (7 charts at 60 seconds per chart). We recommend a smaller Processing Step in Seconds to start with to ensure you are seeing what you expect and then if you want to use a 60 second period then you can stop the replay and start with the increment you want.
