Date/Time: Sun, 24 Nov 2024 16:41:06 +0000
Market Depth Historical Graph not showing up
View Count: 293
[2024-05-11 09:54:48] |
User324251 - Posts: 1 |
When I add this study, clicking apply without making any changes to the settings, nothing appears on the graph. But then I can see that that study has been added because when I look at the chart header, I can see that the study has been added. https://www.sierrachart.com/image.php?Image=1715421125638.png I have also checked that under Global Settings > common settings > Allow support for Sierra Chart data feeds has been selected as Yes. |
[2024-05-11 18:57:14] |
If you have not previously had this study on the chart, or specifically setup your symbol settings to store the Market Depth data, then when you first add the study, you may not get anything except for when new data comes in. In this case, you will want to ensure that you have the option for downloading historical market depth data setup. Refer to the following: Market Depth Historical Graph: Downloading Of Historical Market Depth Data In particular, note Step #8 of the above instructions which tells you how to force the download of missing historical market depth data from a specific time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
