Date/Time: Thu, 19 Sep 2024 21:39:30 +0000
Period OHLC after weekend
View Count: 1242
[2014-08-18 12:17:51] |
User120827 - Posts: 77 |
hi On futures , the previous high, low,close are showing thursday's numbers. If I select "load weekend data" under chart settings, then Sunday numbers show. Is there an indicator setting I can change to reflect friday's data for Previous OHLC on Monday? Is the period OHLC , when set for days, different than the indicator Daily OHLC ? thanks Date Time Of Last Edit: 2014-08-18 12:54:40
[2014-08-20 10:11:41] |
Period OHLC -Variable Periods is different from Daily OHLC. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s294 Tell us the Input settings that you have for this study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-20 11:33:42] |
User021827 - Posts: 174 |
Hi I attached the chart image showing indicator. It shows nothing on monday and the settings dialog box is in image. These are high and low. regards |
periodOHLC.jpg / V - Attached On 2014-08-20 11:30:43 UTC - Size: 237.59 KB - 372 views |
[2014-08-22 08:22:06] |
With those settings, Monday should be displaying the OHLC values for Sunday. But we do not know the Subgraphs settings or the Session Times settings in the chart. We have done a test confirming that this is how it will work. If you want Monday to be showing the Friday OHLC values, then you need to set the following study inputs: Minimum Required Time Periods As % = 50 Auto Skip Periods of No Trading = Yes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-22 08:22:39
[2014-08-22 10:48:11] |
hi Great, thanks for the info. That did the trick. thanks shane |
