Date/Time: Sun, 24 Nov 2024 16:32:45 +0000
Global Risk managment tool
View Count: 188
[2024-05-11 07:25:55]
ShaiVardika - Posts: 13
Hey,
I want to set my daily risk and profit goal, once reach the account will be lock for trading for the day
can you tell me if I understood it correctly
if I set the Profit Trigger Value - 400$ and the Profit Value after Trigger to Flatten Position 350$
so once i'm in a position and the it reach 400$ on the day, when it back to 350$ it will be flatten and lock traing for the day?
also if i unable Trail Daily Net Profit and After Trigger When Daily Net Profit Increase by 50$ Increase Profit Value After Trigger to Flatten position by 50$
meaning if it reach 400$ and then continue to go up to 500$, it will be flatten & lock when it back again to 450$ ?
also I want to set daily loss for 800$
can you please check in the attach image that all done correctly?
imageGlobal risk managment.png / V - Attached On 2024-05-11 07:17:27 UTC - Size: 57.23 KB - 51 views
[2024-05-11 18:54:27]
Your understanding and settings are correct for what you want to accomplish.
