Date/Time: Sun, 24 Nov 2024 16:55:51 +0000
delta fropm numbers bars on another chart
View Count: 191
[2024-05-11 00:54:16]
User509187 - Posts: 22
i have a numbers bars chart which highlights a minimum delta by coloring the bar and i'm trying to put an indicator or highlight on my main viewing chart that notes or shows the delta extreme in some way. i've tried the study overlay but it doesn't appear that it will display that data after fussing with it for a while. is there a way?
thank you
[2024-05-11 18:51:07]
The easiest way to get this value is to have a column 1 in your Numbers Bars set to show the "Ask Vol Bid Vol Difference". Then set the Input for "Highlight Minimum Value In" to that column. Be sure to have the Input for "Highlight Maximum/Minimum Value Based On" to be "Ask Volume Bid Volume Difference". When do this, then the subgraph "Price at Minimum Highlight" will contain the price level of that minimum delta. You can then use another study to place a marker or something at that level.
