Date/Time: Sun, 24 Nov 2024 17:00:11 +0000
zero values on number bars
View Count: 227
[2024-05-10 21:10:51]
User509187 - Posts: 22
is there a way to highlight the text and/or background colors for zero bids/offers on the number bar charts? i can only see highlighting of non zero values.
thank you
[2024-05-11 18:29:39]
The only option for coloring zeroes is to use the "Highlight Minimum Value In" option and if you want the minimum of the Bids and Asks, then be sure to set the Input for "Highlight Maximum/Minimum Value Based On" to "Bid Volume or Ask Volume" and then make sure the Input for "Ignore 0 Values for Minimum Highlight" is set to "No".
This is not perfect, but it is the best option available.
