Date/Time: Sun, 24 Nov 2024 16:32:06 +0000
Cumulative Delta - Volume ZigZag Ask-Bid Difference Volume
View Count: 204
[2024-05-10 19:17:37]
User550539 - Posts: 31
Is it possible to see the volume difference between swing high/lows using the ZigZag study on the Cumulative Delta Bars - Volume study. I would like to see how much volume it took to go between swing levels to show if bids/offers are absorbing.
I changed the Volume to Accumulate to Ask-Bid Volume Difference and Display ZigZag Volume but the values show 0
Thank you!
image2024-05-10_15-04-06.jpg / V - Attached On 2024-05-10 19:14:14 UTC - Size: 59.4 KB - 69 views
[2024-05-11 18:00:56]
There is not a way to view the volume accumulation within the Zig Zag study when the study is used with the "Cumulative Delta Bars - Volume". The reason for this is that the Cumulative Delta Bars have the delta volumes stored in the Open/High/Low/Close values of the study, not the volume itself. And the other volume information is not kept with the study, so that is why looking for the "Ask-Bid Volume Difference" did not work either.
Since this is the accumulation of the Delta, we assume you would want the difference between the volumes from the Zig Zag rotations. To do this, you would need to use the Spreadsheet Study to get the information where each turn occurs and subtract the volumes. You would use the Close volumes to get the accumulated totals for each bar.
On the Zig Zag study, make sure you set the Input for "Additional Output for Spreadsheets" to "Yes", so you can get what you need. Refer to the following:
Zig Zag
Using the Spreadsheet Study
