Date/Time: Sun, 24 Nov 2024 16:42:11 +0000
Sierra Chart remote access
View Count: 368
[2024-05-10 18:42:32]
User746875 - Posts: 30
I'm trying to find instructions on mobile access to Sierra Chart. Specifically, I wish to use my cell phone to remotely access my laptop that has Sierra Chart already running so I could place trades.
[2024-05-10 18:44:51]
You would need to use a third-party tool in order to access your computer and run the Sierra Chart software remotely from your phone. This is beyond the scope of our support. We have therefore set this as a User Discussion for others to give their comments on what you can do for this.
If you are using our Teton Order Routing Service, or the Simulated Futures Trading Service, then we have a web-based portal that can be used with these to access your trades and close or open new trades. It does not have charting capabilities, however. Refer to the following:
Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel
[2024-05-10 18:59:52]
hyp0luxa - Posts: 18
I've used both google chrome remote desktop, and microsoft remote desktop. google's is a snap to configure. both work well
