Date/Time: Sun, 24 Nov 2024 17:00:00 +0000
Chart/DOM Bid/Ask Order Size Histogram
View Count: 278
[2024-05-10 15:25:44] |
User92573 - Posts: 530 |
Dear Support Can you help configure the the attached? Many thanks |
Sierra DOM Bid Order Size Histogram.png / V - Attached On 2024-05-10 15:25:18 UTC - Size: 86.01 KB - 65 views |
[2024-05-10 17:51:24] |
Refer to the following to display the "DOM Graph" on the chart: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-11 16:40:28] |
John, Thank you as always. A solution every time and I was looking in the wrong area entirely. |
[2024-05-12 08:20:34] |
Hi John Quick question. All okay on Saturday following your guidance but the DOM has disappeared on Sunday when trying to run a replay. My Data is Denali with a Rithmic Broker connection. Global Settings >> Symbol Settings (Rithmic) Record Market Data = No. However, I am using Denali and it was working yesterday. Rithmic is only the Broker and as Denali provides my Data I'm pretty sure the symbol setting = No has no impact especially as it was working and my data is independent of Rithmic? Can you provide some guidance? Many thanks. *** Both images shown were during a replay and when market was open *** *** The same occurred whether using Rithmic or CQG *** Date Time Of Last Edit: 2024-05-12 08:45:46
Sierra DOM Bid Order Size Histogram - Change.png / V - Attached On 2024-05-12 08:35:31 UTC - Size: 94.92 KB - 56 views |
[2024-05-13 15:36:39] |
If you are just wanting to replay the Market Depth Data in the DOM, then you really should set the symbol setting for "Record Market Depth Data" to "Yes" for the symbols for which you will want to replay this data. You can also get the Market Depth data from our Historical Market Depth, but recording it up front is the easiest path. Still, refer to the following for how to get the historical market depth data, in particular note step #8 for how to force a download at a certain time where you have missing data: Market Depth Historical Graph: Downloading Of Historical Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
