Date/Time: Sun, 24 Nov 2024 16:46:46 +0000
Aligning text in numbers bars
View Count: 238
[2024-05-10 08:21:21]
mandano89 - Posts: 24
I have a footprint chart with the volume profile in the 3rd column on the right side (see attached image). The text is right aligned, but the volume profile is left aligned. I want the text also be left aligned. How can I do that?
imagenumbers_bar.PNG / V - Attached On 2024-05-10 08:20:35 UTC - Size: 28.27 KB - 54 views
[2024-05-10 15:01:24]
Refer to the following:
Numbers Bars: Single Value Text Alignment
[2024-05-10 15:29:14]
If I set the Single Value Text Alignment to "left" the text of the first column is also left aligned. This is not what I was looking for. The 1st columns text should be right aligned, the 3rd columns text left aligned. Is this possible?
[2024-05-10 17:53:53]
What you are wanting to do is not supported. There is only the one control for text alignment and it affects all the columns. There is no per column alignment option.
