Date/Time: Sun, 24 Nov 2024 17:01:50 +0000
Auto toggle time frame (tabs)
View Count: 170
[2024-05-09 17:44:37] |
DLi - Posts: 16 |
Dear Sierra Support, Hope you are well. I would like to go back and review historical charts for any given financial instrument. For example studying the ES chart on Jan 02, 2024. I have multiple time frame (tabs) of the same instrument (ES) open. Kindly see attached. Is there a way to auto toggle all time frames (tabs) to the designated date? Currently am doing this manually by using Go To Date Time (function). For example, if I am reviewing Jan 02,2024 with the 15-min time frame, could the system allow auto toggle to Jan 02 when I switch (click on) to the 5-min time frame (tab)? Thank you very much in advance. |
Private File |
[2024-05-09 18:18:29] |
There is the option to link the charts for the "Scroll Position". Refer to the following: Chart Settings: Chart Linking >> Scroll Position (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
