Date/Time: Sun, 24 Nov 2024 17:01:02 +0000
Amp sub account
View Count: 193
[2024-05-09 14:55:17]
SafSaf - Posts: 89
hi support, i have two accounts set up with Amp futures and only the main account is showing in my trade window. how do i go about getting the sub account to also be listed please? tia
[2024-05-09 16:21:04]
Both accounts needs to be under the same login information when you connect to CQG. If AMP has set this up this way then both accounts should be showing in your Trade Window.
If the accounts are under different logins, then you can the second account by installing a second installation of Sierra Chart and setting it up to connect to the appropriate CQG account. Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
