Date/Time: Sun, 24 Nov 2024 16:35:10 +0000
Eliminate VWAP Bands from Session to Session
View Count: 262
[2024-05-09 09:04:15] |
User703411 - Posts: 17 |
Hi Support, On the attached image you will see a chart of DAX mini with two VWAP study's. To the left side of the vertical green Euro Open line is the overnight VWAP and the right side is the day VWAP. Both study's are taken from other charts using the Study/Price Overlay study. The overnight VWAP is from one chart with the session times reflecting Eurex overnight hours. The day VWAP is from another chart reflecting Eurex RTH hours. As highlighted on the image, when the day VWAP begins the VWAP bands from the end of the previous day's day VWAP (left of the white vertical line) appears as lines across the chart. I don't know why it's trying to bridge the data gap when I have this selcted to "No" in the study settings (also in the attached image). These lines are somewhat annoying and I'm wandering how to get rid of them? Note: I also trade the S&P e-mini's and the exact same thing appears on this chart too. Please help. Thanks, Alan. |
Images.pdf - Attached On 2024-05-09 09:02:29 UTC - Size: 92.85 KB - 119 views Attachment Deleted. |
[2024-05-09 16:09:20] |
We are not certain which of the following will fix this, but one of these should do it: 1. Change the Draw Style for the VWAP to be "Line Skip Zeros". 2. Change the "Study/Price Overlay" Input for "Bar Time Matching Method" to be "Containing Match". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-09 23:10:39] |
Sierra_Chart Engineering - Posts: 17156 |
Also refer to: Chart Studies: Avoiding Vertical Joining Line for Study Subgraphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-10 06:05:42] |
Brilliant - that's worked! Thanks allot.
