Date/Time: Fri, 26 Jun 2026 05:54:00 +0000
Russell
View Count: 1269
[2014-08-18 04:40:40]
User28682 - Posts: 233
Can I look at delayed Russell quotes (a TF chart)? When I set a TFU4 chart up, it says download failed, so I never get a chart.
Tom
[2014-08-18 06:11:44]
You can by installing another copy of Sierra Chart and set it to use the "SC Historical Data" service. Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html
You can then open a chart for RJU14. The data will be delayed 15 minutes.
You can also set the service to "SC Exchange Data".
[2014-08-20 15:06:14]
Hi, thanks for the guidance. I set this up like you said, with RJU14. Should it bring in a delayed quote by 15 minutes? I have yesterdays close and no updates today? Its a 5 minute chart.
Tom
[2014-08-20 17:09:57]
There should only be a 15 minute delay. We tested this and it worked.
Select File >> Disconnect and File >> Connect to Data Feed.
After this post a copy of the Message Log, by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#log
[2014-08-21 00:43:00]
I cant get mine to update without disconnecting and reconnecting each time?
Tom
Date Time Of Last Edit: 2014-08-21 00:43:17
[2014-08-21 06:57:39]
The data is not streaming so you do have to periodically reconnect by using the commands on the File menu.
