Date/Time: Mon, 16 Sep 2024 19:46:05 +0000
Trade Activity Log empty
View Count: 204
[2024-05-09 02:00:08] |
joshtrader - Posts: 485 |
I just opened the TAL to export trades from the last 3 days. However, the TAL window is not populating. Attached are my settings. I did not clear any trades out, and I have trades from the past 3 days. I did update SC on Sunday or Monday, but I'm not seeing any trades at all, and I'm not seeing any from a few hours ago. What's up? This is something I routinely do and not sure what's wrong.
[2024-05-09 03:04:23] |
Sierra_Chart Engineering - Posts: 16387 |
For the Symbol select just "All Symbols" without any other text.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-09 03:05:03
[2024-05-09 14:19:43] |
Ok thank you, this worked. These are not sim trades but now everything is showing up. After I changed it, the old option disappeared. So maybe a new box (sim/non-sim) was added on an upgrade, and a prior default was left in. Either way it's working, thank you.
