Date/Time: Sun, 24 Nov 2024 17:56:37 +0000
TPO Chart Only show the actual day
View Count: 232
[2024-05-08 18:30:50]
User254184 - Posts: 2
I'm sorry, but I think I've made a mistake with the TPO studie. My chart loads 50 days but only displays the current day.
I don't know what I've changed, if anyone could help me that would be great.
imageimage_2024-05-08_203036183.png / V - Attached On 2024-05-08 18:30:36 UTC - Size: 55.12 KB - 47 views
[2024-05-08 19:18:45]
Are you certain that you can not scroll the chart to the left in order to view other profiles? In other words, is it just that the display only shows the one profile, but the others are really there?
If you are certain that you only have the 1 profile, then the next thing to check is that the underlying data is actually loaded for the amount of time you think. You would have to remove the TPO study and look at the bar data and ensure that you have the data going back as far as you think.
One other possibility is that your Session Times are incorrectly set. Make sure you are not overlapping session times. For example, make sure your "End Time" is set to be 1 second less than the "Evening Start Time".
For example, if the Evening Start Time is set to "17:00", then the "End Time" should be set to "16:59". If it is set to 17:00 (or something that overlaps the sessions) then this can cause issues for the TPO profiles.
