Date/Time: Sun, 24 Nov 2024 17:59:34 +0000
Is there a "fine" adjustment option for x-axis drag?
View Count: 189
[2024-05-08 16:31:09]
User212833 - Posts: 15
When I click on the x-axis (time) I can drag left or right to increase or decrease the scale increments.
What determine the amount of bars or time the dragging will adjust? It seems to move in blocks and I would like to have ability to make finer adjustments
[2024-05-08 16:43:10]
There is not a way to adjust how the horizontal scroll bar works in Sierra Chart. The only option for something like this is the mouse controls within the operating system.
Rather than use the Scroll Bar, you can also use the "Page Up/Page Down" keyboard buttons to move a "screen" at a time, or you can use the "Left Arrow/Right Arrow" to move a smaller amount each time. There are also the arrows at either end of the scroll bar that can be pressed that gives more control.
