Date/Time: Sun, 24 Nov 2024 06:11:48 +0000
2nd instance on same PC not loading Data on Daily Charts
View Count: 667
[2024-06-18 21:27:18] |
Sierra_Chart Engineering - Posts: 17154 |
We time to look into this. This is Rithmic specific. It does not affect other services. This is a complex issue. It may be several weeks before we can get to this.
[2024-06-19 04:48:19] |
User197518 - Posts: 17 |
Thank you
[2024-06-19 11:09:26] |
For now, install a separate copy of Sierra Chart for your Historical Daily charts: Using Multiple Data and Trading Services at the Same Time Follow the instructions here to use the Sierra Chart Historical Data service: Sierra Chart Historical Data Service: Setup Instructions The charts will also update in real time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-19 12:20:34] |
Ok, I will
Date Time Of Last Edit: 2024-06-19 12:20:54
