Date/Time: Sun, 24 Nov 2024 17:42:40 +0000
Rithmic rejecting connection
View Count: 216
[2024-05-08 06:58:59]
User996752 - Posts: 1
I am experiencing an issue with my Rithmic connection. It was working two days ago, but then it suddenly stopped. I have tried opening a clean chartbook with the ESM4.CME chart, but I am still encountering the same problem.
I have attached the message log.
Thank you,
Date Time Of Last Edit: 2024-05-08 07:44:55
imagedownload.png / V - Attached On 2024-05-08 06:55:54 UTC - Size: 532.5 KB - 50 views
[2024-05-08 14:42:06]
Remove, all symbols, that are not Rithmic symbols, or are expired:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
Otherwise Rithmic will close the connection.
