Date/Time: Sun, 24 Nov 2024 18:53:59 +0000
color background of text display
View Count: 163
[2024-05-07 18:47:37]
$tack - Posts: 87
Hi, is it possible to change the background color of a text display study based on some formula condition?
Thanks in advance
[2024-05-07 19:58:26]
It is not possible to do this with the built in tools.
The one option that is available is to change the code for that study to create your own study that will do what you want. Refer to the following:
How to Build an Advanced Custom Study from Source Code
