Date/Time: Sun, 24 Nov 2024 18:30:17 +0000
[User Discussion] - AVERAGE() shows wrong result
View Count: 201
[2024-05-07 17:08:17] |
jivetrader - Posts: 410 |
Please advise on this discrepancy between the actual results and the results shown in the Chart Values window. Provide a better formula if necessary.
Attachment Deleted. WRONG AVG CALC.png / V - Attached On 2024-05-07 17:08:05 UTC - Size: 97.13 KB - 51 views |
[2024-05-07 17:20:14] |
SOLVED: Tool Values window displays the value under the cursor, and the cursor was not located over the last value in the chart. Chart Values window displays the value correctly. However, when overlaying this result to another (TPO) chart, the figure is 49 (or 50, depending on settings in Study/Price Overlay) and this is completely wrong. Are my settings for Study/Price Overlay correct? |
SPOL WRONG VALUE.png / V - Attached On 2024-05-07 17:20:12 UTC - Size: 212.37 KB - 47 views |
[2024-05-07 17:23:37] |
SOLVED: 'Match Source Bars to Destination Bars' must be set to No in Study/Price Overlay. Hope this helps someone else. Cheers |
