Date/Time: Sun, 24 Nov 2024 12:48:02 +0000
A huge gap in historic data SP500
View Count: 249
[2024-05-07 13:53:54]
User266447 - Posts: 253
I have a 7 year gap in data on historic chart on ESM24. From 2014 to 2021 is a gap. Big jump on a chart. Could you support me how to fix it, please?
imagegap_SP_data.png / V - Attached On 2024-05-07 13:52:07 UTC - Size: 54.81 KB - 46 views
[2024-05-07 15:02:41]
Follow these instructions:
[2024-05-07 17:00:38]
It does not work. I still have the gap. Maybe there is another solution?
[2024-05-07 17:35:24]
There is not another solution. Make sure you select all the contracts in the list when prompted.
[2024-05-28 04:44:54]
Sierra_Chart Engineering - Posts: 17154
Do the historical data downloading first in the main instance of Sierra Chart. Not a sub instance.
You might also be running into historical data downloads failures.
Date Time Of Last Edit: 2024-05-28 04:45:08
