Date/Time: Sun, 24 Nov 2024 18:36:19 +0000
Unable to trade EUREX via Teton
View Count: 284
[2024-05-07 09:05:05] |
User628581 - Posts: 4 |
Hello. I recently paid for monthly EUREX data with the expectation that I would be able to trade EUREX products. However, it appears that Teton doesn't offer EUREX trading. How may I obtain a refund? (...and why would you offer EUREX data to Teton users if they can't send orders with it?) Thanks. |
[2024-05-07 14:42:47] |
We can not give refunds for exchanges. Those funds go to the exchanges themselves and they do not give refunds. Our Teton Order Routing Service only works with the CME Group, which is stated on our documentation for the service. But you can still use Sierra Chart to trade EUREX by connecting to a broker that uses CQG or Rithmic for the order routing and then installing a second Sierra Chart to trade with that service. Depending on the broker you are using for your Teton Order Routing, you may be able to do this with them. Refer to the following for how to install a second Sierra Chart that you would use with that other account you would open for EUREX trading: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-07 16:44:28] |
VLiviu - Posts: 223 |
If my install is c:\sierrachart and I want a new install, can't I just copy the original one to c:\sierrachart2 instead of coping the settings by hand from "c:\sierrachart" ? Thanks |
[2024-05-07 17:27:36] |
Sierra_Chart Engineering - Posts: 17156 |
Yes you can do that. Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
